Bottom to top!
Pitbull_SN95
St.Petersburg, Florida
Well this is my first time building a modular engine, but I have built a few pushrods.
I started collecting parts about year and a half ago. I was going to just do a H/C/I swap initially, but I always want more. I ended up deciding on building a FI engine, and going with a turbo. Here's the build list.
Aluminum Block
- Cobra Crank
- Forged Rods and Pistons
- 2v/4v Melling HV/HO Billet Gear oil pump
- Moroso 8qt oil pan
- Moroso Windage Tray
- ARP Main Studs and Head Studs
PI Heads
- Stage 2 MHS Turbo Springs
- Stock Cam
- BBK Longtube Headers
Fox Lake P51 Intake
- Mild Port
- Cooling Mod
- Dragon 75mm TB
- JLT CAI
- Cardone Select Perf MAF
Meziere Electric Water Pump
Fuel System
- A1000 Fuel Pump
- 24lb injectors
- Aeromotive Fuel Rails and FPR
- -10 Braided Tank to Y, -8 Braided on Rails, -6 Braided on Return
UPR Tubular K member / A Arms
AEM Electric Digital Water Temp, Oil Pressure and Fail safe W/B
Bama SF3/X3
**Turbo System**
- 80lb Siemen Deka Injectors
- MP 68mm Turbo
- Canton Oil Relocation Kit
- MHS Stage 2 Turbo Cams
I haven't decieding on which to go with. I might just spend $2200 to get the on3 kit, and use my turbo (MP 68mm), or have a local shop fab a kit for me. Suggestions are appreciated!
Pitbull_SN95
Pitbull_SN95
I always loved this car. It's gonna be even better with a completely new powerplant in it.
Good luck with the build, I can't wait to see all the updates!
Pitbull_SN95
Pitbull_SN95
Well, I ran into a bunch of problems. Not only is it raining every day, but I guess putting a 04 GT tank into a 98 doesn't happen very often. Since I have the UPR K member, they didn't make the hole high enough for the nipple on the motor mount to sit, so the engine doesn't sit correctly. I'm in the process of drilling out the hole for it, but it's pouring rain.
