theres a port next to the fuse box, use a jumper wire and go from i wanna say #3 port to the small grey connector next to the big one. then turn the key to on and count how many times the abs light flashes. your manual should have the information on decoding the light blinks. it will tell you if its a wheel speed sensor or a sensor ring. along with abs pump failure if thats the case.
