brake light
1BAD9D4
hey guys my anti-lock light, located on the guages, came up today. i was wondering on how to check it. is the same thing as when the CEL is on? i didnt know if it was a different port or what not.
joekd
Ct
If it is due to tire size or tone ring it should reset everytime you start the car and stay off until you drive a bit, if it is still on solid as soon as you start the car then you have some hard troubleshooting ahead of you
switch96
If it's on all the time, it's very possible a wheel sensor has gone bad.
sn95gtvert
Spokane Washington
theres a port next to the fuse box, use a jumper wire and go from i wanna say #3 port to the small grey connector next to the big one. then turn the key to on and count how many times the abs light flashes. your manual should have the information on decoding the light blinks. it will tell you if its a wheel speed sensor or a sensor ring. along with abs pump failure if thats the case.
