Cam Help
blackgt96
Alright guys I'm not a genius when it comes to cams. i recently bought a set of custom grind comp cams off of a guy on svtp. he said they are for a NPI N/A 96-98 2v. i know i'll need to buy valve springs for the install but is there anything else i need? would the comp cams beehive valve springs be good for these? here is most of the info off of the spec cards. please tell me anything i may not know about these. also, i already have PI cams in my car now and i'm pulling out the motor to put a new engine in. would i be better off putting the PI cams in or these? thanks!!
part #: 102-000-9L / 102-000-9R
INTAKE EXHAUST
valve adjustment hyd hyd
gross valve lift: .500 .500
Duration @
.006 tappet lift 267 277
valve timing OPEN CLOSE
@ .050 INT: 0 BTDC: 50 ABDC
EXH: 55 BBDC: 5 ATDC
THESE SPECS ARE FOR CAM INSTALLED @ 115.0 INTAKE CENTER LINE
INTAKE EXHAUST
duration @ .050 230 240
lobe lift .2740 .2740
lobe separation 115.0
Staff online
