Cams
96PonyGT
hey guys, im kinda new here but im learning a ton hangin out on these forums all day haha. anyways, I plan on doing the PI intake swap and cams but is there any other cams that would be a better bet to put in instead of the PI cams? without having any trouble either, I figure if im payin to get them in might as well get better ones the first time around....thanks for all your help
Pennywise2
68mustang5.0 said:
so if i did the comp 262 and a PI intake i would find good gains?
Yes.
For the NPI powerband the Comp 262's are perfect and
you will see nice gains too.With the Comp 262's you will not
need to install new valve springs either.
Yellow4.6
I had VT stage 1's w/ a PI headswap, but they do make a stage 1 for the NPI's. VERY VERY NICE cam O0
96PonyGT
right on, sounds like the comp 262's are a good choice, and with the PI intake and these cams I should see pretty decent gains right?
Pennywise2
Yes, you should see some very nice gains with that setup.
I know someone with that setup NPI that ran high 13's pretty impressive
if you ask me for running the NPI cylinder heads.
Pennywise2
gt96stang said:
DropTopPony said:
I prefer the Crower NPI cams....
would you suggest the stage 1 or 2 cams..
I would run the Crower stage one cams since they are more
in the NPI powerband.If you do port and polish your NPI cylinder heads
and install valve springs I would go with the Crower stage two cams.
The Crower cams are pretty good if you ask me.
There's a few good specs out there, but I also prefer the Crower profile.
gt96stang
Yeah, well I was unsure since i'll be adding a pi intake so I really wanted to help wake the car up a bit.. before i throw some nitrous at it that is..
Pennywise2
I would would go the Nitrous Express route to
see some excellent gains. :thumb:
97blackgt
can someone send a link to the stage 1 cams that are needed with the NPI heads please
senior001
