Can you polish these wheels?
BMAC96GT
Virginia
I've always wondered if you could or not. I have a set of these sitting in my room from and I think they would look sick polished. I'm just not sure if they are the right metal or not. These are the ones that came on the 96 GT's, not the later models that came on the 98 GT's. Opinions on polishing them or different paint scheme or colors to make them look better? :dontknow:
badass96gt
Polished they look awesome. Ill be doing mine but Im just polishing the spokes and outer lip and leaving the cutouts painted. You will need to order the aluminum center caps instead of the plastic thats on them now.
BMAC96GT
BMAC96GT
Virginia
Whats your input Handz?? I'm sure you would have an idea on whether or not this could be done
I like this idea. Maybe even paint the lip and inbetween the spokes black and polish just the spokes
I was doing something very similar with my SRT wheels. I was planning on polishing the faces and painting the inserts black but once I got everything stripped off, I found that the metal had some imperfections in them that I was afraid would show after I polished them. There was a SHIT ton of sanding after removing most of the paint and they needed a lot lot lot lot lot lot lot lot lot lot lot lot more to ever be finished. I ended up sanding them all up about the same and having a shop custom-paint the whole shebang. I'm not sure if the 96 GT wheels can be polished but I'll bet that they can. But be prepared, its a LOT of work.
BMAC96GT
BMAC96GT
Virginia
Yea polishing the whole wheel would be a huge PITA...but I've always liked the look of the wheels with the inserts painted darker
BMAC96GT
BMAC96GT
Virginia
WhiteStallion94 said:
They can be polished, however I don't why you'd bother. The 98 Cobra wheels look far better on your car.
Oh yea the cobra's definitely look better...I just kinda wanted to do something different to my old wheels so I could change up the look every now and then
98GTnSC
i miss my old split spoked wheels..... damn island came outta knowhere @ 601mph.. still have 2. but the other 2 you can stick you fingers through the folded over lip.... :(
SRT Handz
most rims can be polished.... All aluminum rims can. I thought about polishing a set of 03 cobra rims but it would be ALOT of work.
cmsismyname
those split spokes can be polished but its a HUGE amount of work I tried polishing a set got half way done and them sold them
SRT Handz
I actually called a got a quote locally to have these wheels polished.... Its 60 per wheel to have them stripped and polished.
BMAC96GT
BMAC96GT
Virginia
So I'm guessing all you would need to go is get a paint stripper to strip the paint, then progressively move from a low grit to high grit sand paper, then polish?
Pretty much. Aircraft stripper worked great on my wheels. Let them soak for awhile. The longer they soak, the more it'll pull off.
