Car is running weird
mikey94gt
The schrader valve is on the fuel rail, kinda by the oil fill on the valve cover.  can you see where the small gage is on my engine? that gage is plugged into it in this pic its inbetween the spark plug wires and the manifold on the LH side as you look at the pic.
I forgot about the catch can trick, I used a Craftsman air/oil seperator that they use on air compressors, it worked decent. it had a small clear catch can on the bottom so you could see when to drain it.
B
boostedGT
Thanks guys for all ur help im going to look into all that. anyone have any ideas where i can get a good oil catch can, how to hook it up and where is a good location to hook it up. also i come to find out that when the car is at operating temp that my collant overflow bottle gets 3/4 of the way filled up and sometimes white smoke comes from the exhaust so its time to pull the eads and check them out and the gaskets. my guess is the guy i bought it from was so quick to get it running that he didnt check it over 100% so its going to get torn apart and rebuilt up 100% the right way. but like i said if anyone can point me in the right direction for the oil catch can and give me some ideas on how to hook it up ill greatly appreciate it.
mikey94gt
Sears, or any hardware store should have the catch can, i just use the one meant for an air compressor. it is called an air oil seperator.
