g36 monkey
hmm, well, as I said, I wanted to change the pump anyhow, so now is a good time to do it and see if it fixes it, along with the crank sensor.
What are other ideas though?
Im off the next two days, I work weekends. Fml
Might be on the right track. Yours is a pita to do compared to mine. Just make sure you buy a filler neck seal/gromet before you drop the tank as it will probably rip. And lube it with vasoline or similar for re install.
Dropping the tank isn't bad monkey. Mostly depends on the condition of everything... I had one strap that was corroded and needed some persuasion. The filler neck is kinda of annoying, but once you figure it out its not bad.
From what you've done to your car you won't have much trouble doing it.
Clogged catalytic converters?
Sums up my whole build. Theres always something.You know chit never goes right the first time around haha
