Car shuts off when A/C on
prstang
Here we go again! The car was running great with the a/c and then it stalled at the stop light. After work I turned on the car and turned the a/c on and the car stalled!Argh!! :help2:
bzubke1
Sounds like the IAC. I would try cleaning it with some carb or throttle body cleaner and see if that helps.
P
prstang
O0Something even simpler. I purchased the iac and when I went to turn on the car. Clic...nothing. Guess what It was the battery. How would I know if the alternator is charging correctly.
Downshift
You can take the car to Autozone and they will test it on the car. Or you can pull of the ALT and bring it in to them and they can test it that way too. Or if you have a volt meter and the car starts and runs, see what voltage is at the battery with it off and with it on. When the car is on you should be seeing 13.75ish-14.3v. Make sure all your cables are connected good.
2slo95fiveoh
Lawrence, Kansas
my car used to do that, it was the a/c compressor clutch went out in it. i could have the car idling fine with the a/c
off, and then turn the a/c on, and it would studder and shut off. i think it might be your a/c compressor. your car doesn't
die any other time, just at idle/slow speeds with the a/c on? the compressor would be my best guess. O0
