car wont start??
brad94GT
ok so heres the story. had the battery unpluged for about 2 months go out there plug it back in car starts first try. the next day the battery is dead. so i take my bros battery off and try it, it only had the power to barely make the windows work but no clicks from the starter with either battery. it has an alarm some off brand one im not sure if thats the problem can alarms drain the battery? i cant drive it witch sucks and im supposed to be shipping money in the mail for parts from members on this site but i cant bc i cant even drive my car. any ideas?? thanks
95Grandtouring5.0
As soon as you put your brothers battery in it.. it only clicked? Perhaps his battery was bad as well as yours? I'd buy a new one.
B
brad94GT
nope it never clicked. i think there might be a draw on the battery. were would i start to look for it. i have no idea???
take the batt and have them load test it. FREE hello. ck the battery cables for corrosion especially inside the insulation. Keep us posted on status
Traidmarx
check the ground wire too...i had the same problem figure out that my ground wire wasnt' on tight enough
x182dan
if your bros battery could barely move the windows what makes you think that the battery is good? I would think that his battery is junk.
B
brad94GT
i never said his battery new or anything it starts his car just fine.
x182dan
what group size is the battery? Usually fords like good cranking amps and good grounds
Traidmarx
i'm willing to bet its the ground...mine'll do that if i don't tighten the shit outta the ground cable on to my neg. battery post.
x182dan
check all the grounds I had a bad ground on the side of the timing cover and it caused my car not to start
