CCRM issues
A_+
This car has always ran like shit but once a year it gives me a good hint about what could be wrong with it and it'll run ok for a while. Well, its year two so it has given me another hint that could possibly make it run better for a few days before taking another shit on me.
KOEO test gave me;
511- EEC permanent ROM test failed
327- DPFE or EVP circuit below minimum voltage of 0.2 volts.
Im thinking these codes have something to do with the EGR or smog being deleted and im running a BAMA chip.
The code that concerns me the most is
556- Fuel pump circuit failure
After a little searching i found that this circuit is located in the CCRM but the info. i find suggest that the whole unit should be replaced. Is that what i need to do? Also, are there specific CCRM's i can use? I googled the part # found on this unit and it looks like its off a 96, i could be wrong though. Ive been googling all day.......
toyman
I can't imagine a mod motor having the same CCRM. From the diagnostic port, ground the fuel pump lead (short side of the connector). With the key on the pump should run continually.
A_+
A_+
Forgive my ignorance on everything electrical, I'm new the the sn95 scene. Coming from a line of fox bodies that never gave me one electric problem. I understand your English but do comprehend. I'll keep searching though. Btw, the only visible numbers on this unit are F6SF-12B577-AB
Edit:
After a little bit more investigation , according to this part #, the CCRM on this 1995 GTS is off
a 96 T-Bird. Is that bad?!!!!?!?!?!
A_+
A_+
Thank you! I found those articles before but lost them! I think I can figure it out.
A_+
A_+
I'm not too smart when it comes to electronics and my volt meter isn't so user friendly,. So just to be sure, i pull the ccrm unit to test it with the meter set to ohms? I put the black stick to a ground and the red to whatever pin I'm testing?
the car runs and drives, btw.
robtalbott
