sounds like it could be the deck, or like I said if you happen to have a factory amp still in there that could be it too. We just had another person on here find that the factory amp under the radio was causing a draw.
Did they check the stock amp directly below the deck as well?
They would have needed to hook up an amp meter like you did and then disconnect the hrns's going to the amp. Its directly below the deck and you can probably even get access to disconnect it front under/behind the dash.
ah cool to hear that. Now either don't go back to that shop ever again or if you do be sure that when you are in there next time that you tracked down that current draw to the stock amp that they should have discovered..... If a customer came into my shop and I took the time to hook up the meter and pull some fuses I would have reached back there and disconnected that amp to see if it was worth the 5 secs it took to do it. They are either lazy or do not give a damn.
Thats the 2nd amp causing a draw in the last 2-3 weeks I think now... Looks like they have started to reach their end of life. Still the best quality and sounding stock stereo ford ever put out.
