Cheap Horsepower?
Ever since i got my car, i haven't dumped any money into my engine bay.
I was wondering if there's any parts i could get that are cheap to get better performance out of my car.
So far i was thinking about getting a CAI, and a new throttle body but thats about it. (searching in the $100-300 range)
I'm not car smart at all, and i could use any help/advise.
Re: How to get cheap horsepower?
No such thing as cheap horsepower. Gears will do a lot more than any minor engine bolt on.
boosted93
Southern Idaho
what he said^^^ The best thing i ever did to my mustang was gears.. So much funner to drive along with making it get up and go!
PI96GT
coupe5ohh said:
you can buy my ported gt40 heads for $280 shipped :)
he's a 4.6 lol.
But once you have the money nothing beats a PI swap.
Gears, PI swap, bolt-ons... Not too much for 4.6Ls in terms of cheap go-fast.
LI98GT
Long Island, NY
Cheap hp for us are pi cams and pi intake with some type of cai. Also seen many used stainless steel mid pipes out there with hight flow cats if you need to stay sniffer legal or without if not. Now "Relatively inexpensive" is the full swap option, but you got a lot more work there plus you need to use higher octane gas from then on.
Dalamar
SLC, UT
Start with gears.
CAI is a good idea, removes a little restriction over the stock filter/box.
TB won't do much for you with the NPI IM/heads/cams. that's where the restriction lies.
for power gains beyond gears & CAI - look at a NPI cam swap, and possibly the PI Intake, or full PI headswap,
other bolt on's are all hyped up and are not worth the cost with the NPI combo.
for your price range, definately start with steeper gears. 373, or 410's
mikey94gt
Im with Dalmar..... Gears are where its at. oh, and a good shifter, cant beat a Pro-5.0. best mod ever though? the driver mod.... get out there and learn how to drive it!
the only thing im not too sure about are NPI cams. what are those exactly? and where can i buy some?
as far as the gears, what set would you guys recommend? is 4:10 too much?
and thank you again for all the help.
Don't fear the gear. I run 4.10s in my 95 back when I drove it everyday. Not a big deal.
mikey94gt
96-98 GT's are known as Non Performance Improved (NPI, 215hp) and 99-04 are Performance Improved (PI 260hp) so, if you do a PI swap, you are swapping the intake, cams, heads and sometimes the T/B to improve performance. It also bumps your compression from somewhere around 9:1 to about 10.5:1 because of the smaller chambers of the PI heads vs the NPI heads. Mod motas love compression and boost, so the bump in compression makes a big difference.
boosted93
Southern Idaho
If you dont drive much on the freeway 4;10s would be fun but if you do (like me) 3.73 are still fun and a big improvment over stock
thanks to anyone who helped. how does getting new gears (4:10 im leaning towards), a cold air intake, underdrive pulleys, a 70mm throttle body, and maybe an o/r h-pipe to really set of my flowmasters. im estimating thats at least 35hp+ and a much more fun/responsive car i'll have.
am i at least somewhat accurate with what i said? lol
Dalamar
SLC, UT
having done all that, and seen a lot of feedback, don't waist your money on underdrives and the TB will do nothing for you with the PI setup, there's no restriction there. Flows are nice for the sound.
don't believe the advertising hype from parts companies :)
