Ciotti's 96' Cobra Build Journal *56k go away*
Ciotti
Back in Feb. of 2006 I bought my 1996 Cobra convertible from a buddy of mine for $5,500 with 111,000 miles on the clock. It was filthy but had a bunch of decent mods installed...
BBK Intake and catless H pipe, Flowmaster exhaust, 3.73 rear gears, big dumb tach, Cobra R wheels, and a "styling" bar with third brake light. The convertible top was in bad shape with 10 or so tears throughout covered with duct tape. That didn't bother me though since I got such a good deal on the car, I just put the top down wherever I went. The car hadn't been washed in quite some time but fortunately the dirt formed a protective barrier under which the paint was actually in decent shape. After a quick wash it looked oh so much better...
To me, the car was a bloody rocket ship so it was then time to take it out and gave it a good once over...
(Right click and Save Target As)
http://www.njaoc.net/media/Karz/Videos/COBRA.mov
The check engine light bulb had been pulled at some point in it's life and when I got it hooked up to a computer there were quite a few codes that needed tending to. Most of them were fixed with a fresh set of plug wires, plugs, and fuel filter.
The search for more power had begun, I first turned to the chrome BBK intake which is known to be awful as it is chrome and heats up like crazy.
I decided to shorten the amount of pipe to get a bit crisper throttle response so I went with a WMS ceramic coated (to keep the heat out) intake pipe and mated it up with the biggest dam conical filter I could find...
The difference in throttle response was fantastic and it felt a tiny bit quicker pulling up to it's 7,000 rpm redline.
Next the alternator started flaking out so it was replaced by a black powdercoated PA Performance unit...
Next I wanted to get the motor spinning up a bit quicker and the clutch had a ton of miles on it so I went to a Spec aluminum flywheel and their stage 1 lightweight clutch along with some fresh trans fluid...
http://www.njaoc.net/media/Karz/Videos/Revvin.MOV
In the quest for more power I got a killer deal on a set of ceramic coated longtube headers with a matching catless h pipe only to realize that they are all but impossible to install on these cars (the whole god dam k member has to drop to get them in) and they've been in the closet ever since...
C
Ciotti
Re: Ciotti's 96' Cobra Build Journal
The ripped top was getting worse and worse so it needed to be replaced, an awful lot of money later the car looked SO much better...
The paint was ok but needed a serious detailing, $300+ worth of detailing **** later including a Porter Cable random orbital and the car looked incredible...
All the while I was running the **** out of the car on the streets and at Atco...
http://www.njaoc.net/media/Karz/Videos/OppositeLock.MOV
http://www.njaoc.net/media/Karz/Videos/June8AtcoBig.mov
http://www.njaoc.net/media/Karz/Videos/June15AtcoBig.mov
http://www.njaoc.net/media/Karz/Videos/Atco5-15-07big.mov
Next up was a killer deal on a Magnaflow Magnapack stainless steel exhaust from a buddy of mine, I couldn't turn down a $680 exhaust for $300 so I gave it a shot to see if I would like it and the result was BRUTAL...
http://www.njaoc.net/media/Karz/Videos/MagnapackExhaustNote.mov
During installation we took the car out with just the h pipe for both ****s and giggles...
http://www.njaoc.net/media/Karz/Videos/OpenH.mov
Then the tires were shot so they needed to be destroyed...
http://www.njaoc.net/media/Karz/Videos/Burnouts.mov
C
Ciotti
That brought the car into 2008 and I had long since grown bored with drag and street racing. I decided to start building the car up for my long time dream of open track racing, first up was a set of Maximum Motorsports springs, poly iso's, Terminator a arms, and Steeda x2 balljoints...
After installation and a good detailing :)
A 4 point bar is required to open track the car but I wasn't quite ready for that yet so I headed out to a South Jersey SCCA autocross event to give the new springs a work out and I was hooked...
(Right Click and Save Target As)
http://www.njaoc.net/media/Karz/Videos/Solo6-8-08.mov
Next up were MM full length subframe connectors, high flow fat cat, poly sway bar bushings, and endlinks (the spacers can't go on until I get longer studs installed)...
They made the car a bit more lively at the next autocross event...
http://www.njaoc.net/media/Karz/Videos/Solo6-22-08.mov
Magnetic autocross numbers were next...
The brakes were in need of a bit of love so I went with DBA slotted rotors front and rear, Hawk HPS pads, and stainless steel braided lines...
That actually brings it up to date, all the while I've been daily driving the car to work and up to see my girlfriend an hour and a half away getting 25 mpg with mixed highway and stop light action if I keep the gas pedal off the floor board (which doesn't happen very often) It is now up to 158,000 miles but you would never know it :eek:
Terrible quality versions of the videos are all up at my Youtube page http://www.youtube.com/user/DeathEaterCobra
C
Ciotti
Towards the end of the year last year I shot one hell of a picture of the snake in all it's evil glory...
And then here are a few shots from the first autocross ever held at Citizens Bank Park in Philly ...
And here's a trailer/raw video of that event, I still have a bunch more work to do on this and a TON more footage but the beginning is pretty much done right now and I dumped the raw video in of all 5 of my runs before the tape ran out...
Downloadable high quality Quicktime version (Right Click and Save Target As, do not stream it the aspect ratio will go to hell)
http://www.njaoc.net/media/Karz/Videos/Solo10-19-08Wide.mov
Crap quality Youtube version (at least click View in High Quality for your own sake)
http://www.youtube.com/watch?v=VSPKAR4J5_4#
C
Ciotti
And a few more pictures from the last autocross of the season last year...
Some say the brown pants shave a full second off his lap times...
It's MEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE I'm the black Stig bitche$!!!!
Here's a link to pictures from the Winter Autocross series that has been going on for 3 months now...
http://sn95forums.com/index.php?topic=35858.0
CanaryGT
Phoenix
Matt94GT said:
sweet man, came a long way, looks wayyyy cleaner now. good deal you got on it too! that 1st pic in the last post is uber cool.
+1
ARdoller
-Never Forget-
man your car turned out great after that first detail! i picked up a polisher this past Fall and have yet to use it... i have no clue where to start, and what im doing! a buddy of mine said he'd show me since he details cars for a dealership, but im getting antsy. my car is definitely in need of a good detail. its got a lot of scuffs, and so many swirls, and a ton of surface scratches from washing it.
Dalamar
SLC, UT
Man, nice work.
and you make it a point to enjoy the car, I'm a little jealous!!
C
Ciotti
I enjoy it each and every day too man, no matter how shitty my day here at work may be going I know that when I leave here I'm going to let rip the demons through the offroad h pipe and Magnaflows which will make all my troubles disappear into the mist I see in my rear view mirror from the car running pig rich :)
Dalamar
SLC, UT
good man, good man.
I like that flame thrower shot, that is just cool.
eliyarbrough
Nocona, TX
That was pretty sweet!!  I kinda wish there was no music on it, though.  The best music my car makes if from the exhaust!  It was great when that song ended.  Never knew your car was in that shape when you bought it!  Good job!!
Oh yeah, that rules out autocross for me. Not that I would ever, though. There is no way I could remember what cones I drive around!!
Hellion94
Ciotti-
How did you support the new CAI? Did you put anything under it, or is it just "hanging"?
ARdoller
-Never Forget-
Steve-Oh said:
I iwsh my car was a vert :sad5:
only about a handful of days out of the entire year i wish my car was a vert. the other 350+ days, im glad i have a coupe. especially in the winter.
JerZeyStangz
Northern NJ
Great cobra man, keep up the good work. In your video, I don't know if the body was flexing or it was the gravitational pull of door, but you can see the gap of your door from the rear body panel get bigger or smaller kind of cool. This was in your autocross video.
95PGTTech
Install the long tubes, fairy boy. 8-10 hours, give or take. It will be a battle but you'll feel awesome when it's done. Really give you some down low grunt.
bwiz760
