Cipher Seats anyone?
infamous209
Anyone got Cipher seats in their sn95 vert? I am wanting to get some soon, seeing as Summits seats and brackets dont fit in my vert.
joekd
Ct
Since when do Summit seats not fit in a SN95 vert? Mine are installed and fit perfectly. As a matter of fact 2 of us posted in your other thread showing how they fit just fine.
joekd
Ct
Look at this pic I took this AM, the seats look factory in there
joekd
Ct
Ok, I give up, why not just change the bracket then? I used Corbeau's on mine, got them form CJ's on one of their sale weekends
I
infamous209
Ill give you the short version called summit before was told they would work, ordered seats, didnt work, called summit asked about different brackets and asked why mine wouldnt work was told only SCAT BRACKETS WOULD WORK, and i needed to contact scat, called scat and was told i was a retard and didnt put them in right, sent scat pics I just posted and they apologized and said return them. Needless to say I am pretty upset with Scat and their BS so returning the seats and brackets which are all made by SCAT.
joekd
Ct
Bottom line, if you are looking for the easiest bolt in then get corbeau seats with corbeau bases, it will be as easy as unbolt oem and bolt in the new ones
Corbeaus were stupid easy to install and im very pleased with them too. I know they're sort of one of the cheaper "name brands" but the seats are awesome and the brackets are legit.
joekd
Ct
It took all of 5 mins per seat to get them to work, flat steel, grade 8 bolts, drill, bolt, done
stprorolla49
Fairfield, CT
Or you could just use your factory power sliders, and drill 2 new holes in them. Thats what I did in my old '95 and they bolted in the car in 5 minutes...
Steven
SC
I just picked up an extra manual seat track, and then welded tabs to fit my corbeaus to it. They sit lower than with adapters, and look much better than if I used adapters. I run corbeau GT7's
I
infamous209
i spent 520 on brackets and seats, so i could just bolt them, i didnt want to fab anything up. i didnt get that so i sent them all back today. cipher seats will work with corbeau brackets so thats where i am headed upon refund.
Jerry santos
