Clearance issues in the back with new wheels.
Untame-d
Here's some pics.
No clearance at all. Less than an inch.
I have Eibach springs and 1 1/4" spacers. Thinking of going back to stock. Or even a coil over. I need to raise it either way with a stiff spring so it doesn't tear my tires up.
What should I go with?
94-427
The convert for your year has a stifer spings in rear [extra weight] and use stock front springs
Untame-d
Untame-d
What convert?
The fronts will be staying I want a lower stance in the front.
Untame-d
Untame-d
I need to lift it. It will still hit the rolled fenders.
Untame-d
Untame-d
Was also thinking 1" spacers instead of 1 1/4" and roll the fenders. But rolling the fenders is a whole lot of trouble without a roller and I don't want to do all that if it might still hit the fender.
I might have to go all of the above.
1" spacers
roll fenders
stock springs
stiffer shock
s..o..b...
BruhBrahBrad
Dont do the stock springs PLEASE!!! Do you have Isos or not? If you dont maybe try one on the bottom.
Untame-d
Untame-d
I'll be checking tomorrow. Then get a set of poly's from americanmuscle if I need some.
Untame-d
Untame-d
275 on 18x10. It's wider than the 275's I had on my 17x9's.
Untame-d
Untame-d
Took out the 1 1/4" spacers and rolled the fenders abit myself. Took it for a good rip around town and minimal to no issues. This is how it looks:
Not too bad still. I will still be checking and getting poly urethane iso's for the rear though.
Untame-d
Untame-d
3/4 would be perfect but I didn't know if they made them a hub centric adapter that thin.
JiMi_DRiX
Tucson, AZ
275's arent quite wide enough for a 10" wheel, are they? I like how the height of the wheel and tire fill the well up though, very nice.
Win
Kennesaw, Ga
Most D/R's will say a 10" is optimum for a 275 . I know my M&H D/R said 10-11"
