clutch pedel
carramrod98
afrew days ago when i got on it, i mashed the clutch and shifted to second and my clutch dissapeared, like stuck to the floor. I put my foot under the pedel and i pulled on it, it gave resistence but then released. It was fine till yesterday, but it happened again. Same deal i just gave a good pull on it, but does anyone know why this keeps happening. :dunno:
reivaxtorres
if you still have the stock clutch quadrant, i wouldnt be surprised if its starting to act up. the quadrant is the plastic part under the dash that the clutch cable rides on.
reivaxtorres
yeah, steeda makes some. if you go with an aftermarket, non-adjustable one (better because its not made of plastic like the stock one), you will need to get the firewall adjuster so you can properly adjust the cable.
C
carramrod98
im sold on 15 shipped. im just flat broke right now, so ill go sell some blood or something lol
ill pm you in the near future
reivaxtorres
if you need the firewall adjuster i have one, practically brand new, i think i only test fitted it once. i told a friend of mine he could buy it off me, but i havent heard from him. ill check with him and if he doesnt want it anymore its yours too. just gotta figure out what i want for it. how much is a kidney going for these days? just kidding, ill prob take $20 shipped for it. just gotta make sure my friend doesnt want it
SRT Handz
You need a new clutch, your clutch is probably shot.
I was driving my car one day and when to shift into 3rd and the clutch wouldnt come back off the floor. Clutch was Gone.
2REDSTANGS
are u saying you can adjust where the clutch engages with out buying anything that would be awesome
i like when they grab right off the floor mine you have to let waaay out
^You are gonna hate shiftin with a setup like that 2red. every time you granny shift or rip through teh gears your gonna have to push the clutch all the way in. i like mine to disengage quick in the middle helps with shiftin. but hey, you might like it. i know i wouldnt though. :thumb:
2REDSTANGS
I love it like that just like my RSX was less than a 1/4 inch off the floor it grabed.
i always push the clutch in all the way anyhow
reivaxtorres
mike97gt said:
how do you go about installing the firewall adjuster?.. i'm sick of where my clutch engages.
thats easy, there are 2 7mm or 6mm bolts that hold the cable to the firewall. you take those screws out, take the cable out, insert the firewall adjuster, and then using only 1 of the screws, you bolt it in. save the other screw incase you ever go back to stock. on the cable, you are going to have to take off that rubber thing it has.
i had it like that, it was ok, but it got tiring after awhile. i had it to the point where the pedal was lower than the brake pedal, and it engaged as soon as you took pressure off the pedal. didnt like it afterawhile, and no the pedal is slightly higher than the brake, and it engages about 1/4 of the way from the bottom.
reivaxtorres
atrainsgt said:
Hey X I'm going to have to talk to you about the clutch setup tonight.
ill sign on to aim in a few minutes, i dont think ill be home tonight, at least not till late anyways. :happydrunks: (<-- ill be the one on the right....)
C
carramrod98
Well the clutch only has about 5k on it, and it still clamps real hard, just does that weird stick to the floor thing every now and then. when its on the floor it still works, just has almost no travel,
reivaxtorres
hey, my friend just went thru a simliar problem, where the clutch would still work, but it would pretty much stay at the floor. turns out the spring on the factory clutch quadrant was binding. he fixed it and now its as good as new
