Cobra (PBR) full brake Upgrade (PICS)
martin12
Before i did my upgrade, I red all of topic to do my upgrade and tank you, you were a great help.
I hope my topic is going to help some one.
It's one of my best improve on my Mustang
Before OEM brake 1994
I bought a PBR Calipers
but I dont like the red caliper
I used a VHT caliper paint + clear
I used a Maximum Motorsports Complete Stainless Steel braided
It come with 2 set of banjo bolt
I used a Brake Master Cylinder, 1994-5 Cobra, 15/16" bore, from MM
Master Cyl. Adapter, 94-95 Cobra M/C, 94-95 w/Stock Prop. Valve. From MM
Brake oil
13 '' rotor
I did a litle refresh in the back
I made this upgrade with your help, thank you
SN95.com is a treasure of information
Mustanger
Southern Oregon
Thanks for this info...I am just about to embark on this project...I have most of the parts just need the bolts & dust shields...unless the GT shields can be used still?
vermilion
maryland
i do know the 99 & up GT banjo bolt is different. M10 x 1.5 (fine thread) they need to be about 30mm long. Being as so theyre aluminum, the threading takes very little torquing. i had to use a little copper RTV along with the copper crush seals.... In my personal experience installing them, i had to shave part of the ear off where the SS line-to-caliper ties together. theyr'e is a good write up on another site. the hardest parts installing the brakes were shaving the spindles for caliper travel on the bracket. i also reused the bracket-to-spindle bolts that came on my 96. i bled the brakes with speed bleeders and keep plenty of fluid handy to keep filling the reservoir.
martin12
thanks
The brakes on my Mustang were the original caliper for 1994 with a Saleen decal.
