So I've installed a front HAL QA-1 tubular k-member under the front of my 1996 Cobra. When installed I installed the 2003-2004 front lower control arms as well. the problem with this was I couldn't achieve the correct alignment geometry with this setup. So after some careful research, I purchased the fox-body tubular lower control arms along with a complete front coil-over kit. After installation of the coil over kit, even at lowest setting the vehicle doesn't seem to want to drop very far if at all. I've moved the spacers around for the maximum motorsports caster camber plates still no help. Does anyone have any ideas to drop the front end down some more?
