Coilover ride height issues
94Pro-5.0
Little Elm, TX
i have MMR front and rear coilovers with Qa1 10" 300# springs. I have the coilovers maxed out to where i cannot go any lower, but my car looks lifted. The only thing i can think of is i need shorter springs. anyone else have any ideas? this is driving me crazy
Duke
What are the spring dimensions? Also, it could be because the tire has a short sidewall. What is the rim size?
duff daddy
10" 300lb springs.......... I run 14" 175lb and have 12" 150lb springs sitting as back up if needed.
94Pro-5.0
94Pro-5.0
Little Elm, TX
i dont understand how you could run a 14" spring. if i had a 14" spring my front bumper would scrape the ground because it would be so raked.
i have to run a stiff spring to make sure my rear tires dont hit the 1/4 panel.
blkmcnasty said:
That picture in your sig looks cool. What happened to that stance?
that was without any springs. i just used a jack to get the wheel where i wanted to see how it would look. now its time to make that look work!
Flar
He is talking about using a 14" spring for the front. In the rear the 10" might be to much, try getting an 8" spring.
