coilovers
moot09
I have the eibach pro kit now and its not low enough for me. Ive looked into sportlines but idk. anyone running coilovers? also if you were to install coilovers would you have to take out the lowering springs?
before you lower it more look under the car to check clearance hate for ya to lower it more then drag on a pebble
moot09
ha ya i hear ya but i got good clearence. i dont really scrap on much excpet for speed bumbs and thats only if i dont slow down enough
mustang9899
Yes, you would no longer need the springs as the coil overs use new springs mounted on the shock. You could then adjust the ride height from the shock. You can also use extended front ball joints and adjustable rear lower control arms for maybe another 1/2 inch of drop and keep your existing springs. Just depends on what your looking for, lowest ride or handling. Going to low without major changes to the geometry will degrade the handling.
