Coming together! Woot! Pics/Vid
Adam95GT
Well its taken me 3years but the car is almost one piece again. All of the work was done by me and my friend Chris (95pgttech) who i couldn't of done this without. (many thanks man) He let me keep the car at his place for the last 3 years. Dont be to harsh this was my first time doing any bodywork/welding or tackling anything this big in general.
I drove it around a bit today and the tune still needs work. (Lean on CL tip in). So i disabled CL at idle and that solved the problem for now. I cant wait to dial this thing in and get some numbers. The car turns alot of heads but thats probably because it needs paint bad. Im out of money to use on this thing so maybe next year.
http://s28.photobucket.com/albums/c236/blindfoldedhope/?action=view&current=DSCF6196.mp4
I still need to mount the switch for the line lock, mount the push pull cut off and do a few other odds and ends. Id also like some quieter mufflers car is to loud.
Very nice car, I remember seen your car everytime chris posted pics of his cobra in the garage.
And what's all done to the engine? I see you have the Fox tb conversion and TFS intake.
dutch said:
awesome adam, that engine bay is sick
And Dutch need to upgrade to pro.. Lol
boosted93
Southern Idaho
Very nice! That bay looks badass! Are those 17s or 18s? Also you could primer that hood back and it should look a bit better :D
A
Adam95GT
Car is a 1995 Vert with 222k on the clock.
Here is whats done:
0.030 Overbore 302
Keith Black Flat Top pistons
TFS/KPI HiPorts Cylinder Heads 2.02 intake valves
Comp Cams Pro Magnum 1.6 Roller Rocker Arms
Trick Flow Hardened Pushrods
Wolverine 1190 Cam
Trick Flow Track Heat Intake Manifold
Accufab 70mm Throttle body
Accufab 70mm EGR Spacer
FRPP Underdriver pullies
Trick Flow Specialties Valve Covers
Trick Flow Specialties billet fill tube
Custom 3'' Mandrel Cold Air Intake
90mm Lightning Maf
24lb Blue Top Injectors
Walbro 190LPH Fuel Pump
Custom Accufab 1 3/4'' headers (3'' collectors)
Custom Mid pipe 3'' pypes cats V band connections
Flowmaster American thunder Catback
FRPP Aluminum Drive shaft
Tubular QA-1 K member
9mm FRPP Spark Plug Wires
Autolite 24's
MSD Distributor Cap and Rotor
MSD Coil
Lokar SS Braided Flexible Dipstick
MR. Gasket 180* Thermostat
C&R racing Aluminum Radiator
Moroso Overflow Tank
Steeda Aluminum Lower Control Arms
Eibach Sportline Springs
Tokico Hp Blue Shocks and Struts
Kenny Brown Camber/Caster Plates
Ingall's Engineering 17mm Camber Adjustment Bolts
Hunsaker Racing Seats
Battery Relocation
98 tails
Cobra R Hood
Chopped Antenna
Mach 1 Lip
Redline Hood Struts
FRPP Hood Pins
Line Lock
Slotted Rotors
New Brake pads
New Rear Calipers
New Master Cylinder
New Starter
SS brake lines and All new Hardlines
Low Mileage 94/95 T-5
MGW Shifter
Hurst Shifter Ball
Poly Motor Mounts
New Ultra Clear Head Lights
StangMods 6,000K HID's
New Ball Joints
New Power Steering Rack (somehow the inner tie rod failed already)
New Inner Tie Rod
Poly Offset Rack Bushings
Polly Swaybar Bushings
2'' Poly Endlinks
FRPP King Cobra Clutch (New Throw Out Bearing)
Fire wall Adjuster
Clock Gauge Pod
Cluster Surround Gauge Pod
Autometer Sport Comp II DPSS Stage 2
Innovate LC-1 Wideband with DB Gauge
Autometer Sport Comp II- Electric Water Temp Gauge
Autometer Sport Comp II-Electric Oil Pressure Gauge
New Gauge Cluster
New Convertible top lift cylinder
Cobra R Wheels (17x9 fronts with 245/45/R17's TOYO Proxies 4, 17x10.5 Rears with 315/35/R17's)
Tuned With: Moates.net Quarter Horse and Clint Garrity Binary Editor and EEC Analyzer
25lb weight removed from fender
Dogbone Removed
Rear Seat Delete
A/C delete
Smog Pump Delete
Quad Shocks Removed
Shortened Dayco Belt
New Windshield
New Top, Pads, Rear heated glass
New speakers
New cLock Spring
Welded Steering Shaft
I think that about covers most of it im still missing alot probably...
A
Adam95GT
Thanks Everyone!
dutch said:
I know, photobucket is kicking my a*s.
As all of your cars have over the years, yours continue to look great... Funny how me you and chris go back lol.
Congrats on ROTM
I have to ask this,
Why did you go with the camber bolts when you have CC plates and also did your car develop any vibration at highway speeds after the dog-bone was removed? Mine did, thinking about put back on.
A
Adam95GT
Javi said:
I have to ask this,
In order to get camber in to spec i needed both. Im running a qa1 tubular k member with stock sn95 control arms. Tubular k members are designed to work with a fox length A arm. Our A arms are one inch longer, that being said the wheels were pushed farther away from the shock tower. The camber bolts fixed this issue.
I have 0 vibration with the dogbone removed. Do you have an aluminum drive shaft? The rule of thumb is if you have one you can remove the dog bone.
A
Adam95GT
knuckles4696 said:
great car, congratz on getting her all done up. looking forward to seeing this car with some paint.
Its gonna be a long time. I have crazy student loan debt and dont see having money to do it for some time. I could always rent a booth and spray it my self. I did the engine bay and it turned out ok. I only work on the car and drive it on the weekends. It stays in NJ and i just recently moved down by DC.
Nice job!
If Chris was working on it with you then you know it was done right. Just by reading his posts on all the forums you can tell he is a perfectionist.
A
Adam95GT
DropTopPony said:
Nice job!
We both are... its a problem some times... it takes us awhile to get things done because we want it done right. The budget for this car was super low so we made do with what we had. I was cruising around 130 yesterday with it. The cars home is in SNJ
I had about $1200 in the motor and about $800 in the headers.. the rest was all small purchases.
dutch
Adam95GT said:
Thanks Everyone!
Congrats on ROTM
Thanks man, sure is funny! Love what you did to the car!
97stanger
nice bro! where at in SJ? I live 5 mins from Route 130...if your ever in the area again we should meet up and take some pics and do some pulls ;)
Gotcha! and yes i have an aluminum driveshaft.
maybe i should get it balanced as the drive shaft wasnt meant for a mustang lol
A
Adam95GT
Did you try to change the orientation of the DS??? clock at different angles? Thats where id go next.
thorco3
IN
Love the smoothed engine bay. What kind of material did you use for the fender pieces? I've got some pics of similar setups saved... if/when the motor is ever pulled from my car I will most def be doing some kind of setup to fill all the holes or just angle in some decent sheet metal for a similar look to yours.
hndaklr
Ya that smoothed engine bay looks kill, you don't see it as much on sn cars
Compared to foxbodys .. Again I'm from surrey BC Canada don't see much different stuff up here haha but looks good I wanna do mine like that
