Complaint on this forums mirror help
caseypayne69
Alright, first off I love this site. Its one of my favorites and thats why I come here from time to time. But some of the knowledge here and left me a bit fired up. NAMELY passenger side mirror removal and installing.
I did a search for side mirror here.
http://www.sn95forums.com/forum/index.php?action=search2
All these threads simply say, remove the plastic triangle pod and unscreew the three bolts, boom your done. Wrong, WRONG. I took this apart only to find out the power cord connecting my mirror is deeper in the door and is bolted down so it won't shake or budget. SO NOW I'm forced to remove the door, which I'm unsure of.
Notice in my pictures, you can't get to this by hand, nor will pliers reach correctly. Now, I feel better after venting this sites bad mirror advice.
Anyone know the PROPER step by step procedure to remove the inner door trim?
[attachment deleted by admin]
94Pro-5.0
Little Elm, TX
yeah dude, its simple
remove the plastic around door handle, it just pops off
Pop out plastic "door pull" panel
unscrew the 2 phillips screws behind that
unscrew your door lock knob (or handle whatever)
Pull up on the door panel and walla
C
caseypayne69
ima gonna try to take my door off this week end. I've made several attempts at lifting it. but something keeps holding it. I have the mirror plate off and yet something still keeps it from coming up. Does the inner door trim come off in two parts? or is it one big piece? Is there a screw to remove some where before I lift the door off, i'm assuming u lift it off. I really REALLy don't want to break my door trim.
94Pro-5.0
Little Elm, TX
there are 2 screws going into the door behind the interior plastic door cup (the part you pull on the close the door)
C
caseypayne69
So i pull the 2 plastic pieces off before the door. The plastic area holding the window and lock switches & the plastic around the door handle? And then there are screws under the door handle plastic?
scarface
Guest
[TxCobrA98 said:
how about you do a proper write up then once your done?
they ya go...if you have a compliant write up something better for the next guy.
DUDE you are WRONG when i took my mirrors to the body shop to get the painted,i didnt take no door panels off
C
caseypayne69
Why don't you look at my second picture in my first post and tell me the door doesn't need to come off.
You can't fingers, pliers NOTHING in that hole to pinch that loose. That cord in the picture is the cord to my Power mirrors. If you pull on it, it goes no where its stuck in place even after you pop it off the door. The door must come off for the mirror to come off. Yea, sure the three nuts holding the mirror were not a problem, its when you find the cord and get pissed, is the problem. I'll probably take pics and do a wright up when I do it.
Did you remove the black pin there is inside. like between the inside part of the door and the fender? try that
BOS-94-003
Isn't this a little overbaord for a wire. Yeah the post might not of mentioned it but it is not this big of a deal. Anywyas hope you got your mirror replaced.
