COP conversion
FrankenStang
bum****egypt
be carefull about ebay electronics...i got 2 02 sensors and they went bogus after 3 months only...also if im correct you wont see any HP gains from a cop conversion..All it really does is make the engine bay abit cleaner and alot more expenive when its comes time to replace sparkstuff..But honestly,i like the way the coilpacks look and how the wires feed to the sparkplugs..
vermilion
maryland
No different in performance as stated. Personally i didnt like the cluster bomb of wires. I needed a accessible spot for pcv breather. I get COP cheap.
Sent by smoke signals
clark98gt
Pennsylvania
No you can't, I actually stripped a harness from a newer mustang 2 days ago to see if I could and most of the wires need changed around. The 96-98 use " waste spark" or something like that and the new edges don't.
metalman302
Does the 99+ engine harness connector fit the 96-98 computer harness? I wanted to go this route... Should just be a matter of pulling 4 pins from the connector and splicing those wires to the correct trigger.
vermilion
maryland
no the connector is structurally the same but all most pins are different. you could repin for hours and curse at your wife or dog. you can buy/build the harness and go that route.
96GTPlanB
