couple pics, installed the MM plates
Steven
SC
Installed my MM plates, still need to get it aligned but I figured i'd take a couple pics.
not bad for a faded pink laser red ol mustang :D
lrall
have you tried gettin a cutting pad and PC and tryin to 'bring her back? Ive seen it done
Steven
Steven
SC
na to be quite honest i'd have to pay somebody who's a pro at it to do it.. I have neither the patience nor the experience to really make it right.
Red96GT
That's a little faded, you can't bring it back.
Did you do the caster/camber plate install yourself? It must be the angle but it doesn't look like the strut shaft will clear the hood. :dunno:
SRT Handz
that paint can be brought back......i used to think i couldnt detail now look at what i can do. ;D Just go out, Buy a PC and try some Buffin'
Steven
Steven
SC
Yep, Not hard at all. MM gives you options on setting the suspension up and i choose to do it that way to allow for more travel. The strut clears fine mainly because the hood I bought is more "oriented" for extreme camber/caster and all types of setups. Clears fine, the hood is molded in with cut outs >:D Yea I might go after it. What do yall suggest to save the paint?
Lightning Struck
that engine bay pic, the elbow at the TB looks smaller than what it is say around the mass air ???
94darkhorse
Idawahio
Exactly it won't be that hard. Just get a pc and a cutting pad with some form of cutting compound, then a good paint cleaner and glaze should finish it off.
dutman98
3m makes some nice rubbing compounds. I would go with some perfect it 3 for the cutting and finish it off with a black waffle pad and some swirl remover.
Steven
Steven
SC
SRT Handz said:
is that a painted Ebay CAI?
yep.. it surprisingly matched the red sorta.. it was like 50 bucks and i was annoyed with the stock crap plastic
