Ok so as my t5 was sitting in my backyard half apart I was curious and just checking things out. I noticed that the input and output shafts had probably 1/8 to a 1/4? inch play up down side to side but not in and out. The output was a little more than the input shaft but not by much.
The countershaft is perfectly solid like I expected the input and output to be, so I pulled them out and the bearings seem fine?
Could it be something else or should I stop being retarded and just get the new bearings already and be done?
Best/Cheapest place to by them?
As a kit or just the two or so I need?
Kinda confused on how to pull the output shaft apart. All the manual I was reading said was to "use suitable puller behind 1st speed gear? No pictures or anything.... Any help will be greatly appreciated Thank!
