Dead Pony
You guys probaly already know, but for those who dont, I just did the full pi h/c/i swap, messed up on my timing, and blew the motor. Well I rebuilt it, got the timing right this time (sure of it, promise!), but still no go. I have the battery unplugged right now hoping to reset the computer, but I did that once already and it was a no go. Im getting everything besides spark. any ideas?
realitygt
blown fuse? bad ground?
check the coilpacks and make sure the connectors are pluged in, then make sure the plug wires are good.
B
Thanks for the input. I kinda thought the same thing so looked around and found two connectors unplugged, but no where to connect them. I will take pictures in the morning, maybe you guys could help me find their home?
reivaxtorres
where are the 2 connectors that you found loose?
1) make sure the crank sensor is plugged in, and make sure its not damaged. they can get damaged when you are putting the timing cover back on
2) make sure the cam position sensor is plugged in. its under the driver side coil pack
3) make sure all the plugs are on in the right order.
just wondering, how did you test to know that you have no spark?
