Saint
- Joined
- Jan 29, 2012
- Messages
- 949
- Reaction score
- 30
Will a bad relay inside a CCRM cause a no spark issue???? Such as no spark at the coil or plugs.........
Thanks
Thanks
The CCRM has the fuel pump relay, Hi speed rad.fan relay, and lo speed rad. fan relay, and the a/c relay..
No spark can come from the dizzy, or the TFI module (ignition control module under the air filter), bad coil.
Ultimately spark is controlled from the computer. But those are the components that tell the computer what's up.
Doubt that's your issue. . How did you check for spark?
keep in mind before this happened the tach needle bounced like crazy with no actual rpm change. Car sound fine and ran fine then just shut off
Id be looking at the ground wire off the coil. Did you check to see if the coil is energizing?
A bad CCRM can indeed cause a no spark issue.
I have a spare if you want it. The ccrm from a v6 will work if it's the same. Should have a big R on it. I believe. .
