My drivers door has to be slammed to make it shut. It sometimes does the 'creak' when i open it. Do i need new door pins/bushings or what do you think? I have done the grease hinges and had my body guy 'adjust' it soooo
lr
Stand at the back of the door and see if you can lift the door up ** hold it at the back of the door bottom edge and pull straight up.* while your doing this look at the door jam if you feel movement look at the pins and see what exactly is moving.
