door panel loose
Orange Stang
hey guys, the bottom of my door panels came loose, and im wondering what i can do to fix them. The push pins are in, just the very bottom.
any ideas?
castine917
wyoming, mi
i would guess pins or holes are worn. can you see if they are? is panel catching on something when you open or close the door causing panel to loosen?
GT Rob
Houston Texass
dose it make the noise when the door is close if it does theres a hole in the front bottom inside the door panel mine was missing check that
he is right that on the part that normally closes into the door jam there is supposed to be a ;plastic push-pin that could be missing.
Tou can try just throwing a screw in the lower carpeted area. If you do it right it would be hard to see and fix any problem.
