Door panel question
07GtS197
Fort Myers, Fl
All interior pieces will interchange from 94-04. The colors are not the same though. For example 94-98 had black interior while 99-04 had dark charcoal interior. I think medium graphite is the only color that didnt change.
damon81nola
New Orleans
Yes they will. As 07GTS197 take note of the colors and also if it/ or your car has the Mach system. There’s a slight difference in the doors in the top area which can be cut out
just to clarify though, you can add the tweeter to a non-mach panel by cutting the bottom of the tweeter enclosure off. But if you get a mach door panel and do not have the tweeter it will look a little funky where the tweeter should go like something is missing. So your fine no matter what if you get a non-mach door panel but if you get a mach panel you will need the tweeter pod to fill the hole.
