Double Din ?
tango7
For those that have done the double din radios I have a question.. I am in the middle of this in my 99 cobra. When you change to the 01-04 radio bezel does it fit correctly after removing the tabs on the dash are removed and did your shifter boot fit..
the shifter bezel is different and will need to be replaced as well. AFter the tabs are cut out of the center of the dash, if there is enough clearance the deck/dash should pop right back in place.
