efi intake
T
titokang
Guest
Hello everybody, I'm liking the look of traditional square bore carb intakes fitted with a throttle body elbow. But all I seem to find are edelbrock super victors and that's too much intake. I'm looking for something a little more streetable but don't know if there's anything else out there, if you guys are running anything like this let me know your setup. Thanks
Magic
Some time zone
What is the rest of your setup?
You might have to go custom, example: use a Victor jr style intake (if the Super Victor is too much intake) and have some injector bungs welded in and some blank fuel rails modified to work.
I wouldnt bother with a dual plane intake (Performer or Performer RPM).
94Snake
Valdosta, GA
+1 and if too much intake is the case why wouldn't a regular efi intake be sufficient for you?
Paul
If you're looking for streetability, the elbow-style intake probably isn't for you. The traditional EFI 5.0 intakes with runners create better torque across the powerband.
What is your current combination?
T
titokang
Guest
im just running gt40 heads and a b cam, with a bbk throttle body and #24 injectors and 3.73's, .030 overbore. Im running a stock intake and just overall would prefer the look of the elbow style intake but just wanted to ask and see if theyre was anything available besides the super victor.
T
titokang
Guest
Thats my point, but i guess im better off buying a cobra or trick intake then. Also i saw one by comp cams called the powerbox. Its an upper intake and made of polymer has anyone used these before? thanks
