eibach sportlines.....removing isolators
94Pro-5.0
Little Elm, TX
well i have noticed as most people have that the sportlines make the car sit really low in the back and slightly higher in the front, and most people removed the isos from the front. i have not messed with my front suspension yet so i was wondering if there is anything i should look out for or do before or after i take out the isos. is this an ok solution to lower the front? anyone have any problems?
94Pro-5.0
94Pro-5.0
Little Elm, TX
ŠçÀRƒÀçÈ said:
it will do what you want but there is a chance it will creek and pop.
is there anything i can do to keep it from creeking and popping? would it be better to keep the isos is and just cut a 1/2 coil off?
scarface
honestly I cut a coil off mine drag springs and had NO problems with it, when I went to sportlines I removed the isos and had alot of noise.
