Electrical problem stalls engine
Kevman74
I'm having a problem with my 96 GT. I started it yesterday and when I turn on the park lights the engine runs rough and then stalls. Same thing happens when I put my foot on the brake pedal. The signal lights blink fast and my break lights go dim. I cleaned all the grounds I could find and that didn't work. The only thing that seems to work is when I leave the battery disconnected for about an hour and then everything works fine for a bit. Any idea what it could be?
sounds like you have a battery going bad and possibly an alternator. Take the battery out and drop it off at autozone and leave it with them for a few hours. Have them put it on the charger, then wait a couple of hours after it finishes and then test it. I say to wait because I have seen batteries that come off the charger that tests good but with nothing hooked up to them they start to drop voltage over time. If the battery tests good then have them test your alt
K
Kevman74
Yes I thought that also. The battery was put in 2 weeks ago but that doesn't mean it's good. I'll get it checked tomorrow and go from there.
cobrajeff96
Germany
Make sure the car has at least 14 volts when at idle. You'll at least know if the alternator is putting out.
It's not uncommon to have a significant voltage drop even if everything is working as it should, such as when you put a lot of load through the electrical system (stomping on brakes while A/C is on full blast with stereo blasting and operating window switches simultaneously... all while at idle speed.
But if there's no significant voltage drop as in such a scenario but the system is still giving you problems, that's usually an indicator of a failing alternator because it's a 12 volt system and everything in the car needs at least that in order to work well. Ideally, it's a little hotter at anywhere between 13.5 and 14.5 volts as with alternator output.
K
Kevman74
So I took the battery to Napa to have it tested. They tell me the battery is good. They were good enough to give me a new battery to try. I've put the new battery in and it worked fine for a bit and then I have the same issues with it stalling when I turn on the park lights or put my foot on the brake. Alt is charging at 14.4v.
cobrajeff96
Germany
That's weird. So if you were to only turn on the parking lights, no foot on brake, the engine will die?
cobrajeff96
Germany
I couldn't think of another culprit. Wiring could be a factor as well.
K
Kevman74
Yes looking at everything now. I just pulled the seats out
K
Kevman74
I forgot to mention that I have a convertible. So I found a bare wire underneath the back seat that goes to a relay that I think is for the convertible top. Fixed that but no difference.
K
Kevman74
Just found these. No idea what they are for. Someone was having fun with the wiring on this car I'd say.
I had a problem with my cruise control a while back that I could not understand but for some reason with the module plugged in, the brake lights would only see 9.5 volts. With it disconnected they see full power. It is easy enough to disconnect to test to see if that could be causing a strange problem like this.
cobrajeff96
Germany
Ever since I Coyote swapped, the CC module has been removed. I'm actually kind of curious to see what would happen if I installed it again.
weendoggy
I can tell you I left my CC in with cable in the fender well. Actuating the switch does nothing and it doesn't interfere with the cars operation. This is AFTER my swap. I am going to play around with it this winter, I have an idea!
JohnnyOctane
