elminator or no
95bananaGT
so i got some cash..do you guys think i should waste my time buyin a smog pump eliminator pulley or jus run a smaller belt and second...once i remove the pump how do i cap the lines?
Win
Kennesaw, Ga
Just because vehicles are older then 95 doesn't mean there bad. I wouldn't even bother doing a smog pump removal..... Your going to gain a few HP that's about it.
95bananaGT
im sorry i said that wrong....i meant to say is that i dont buy vehicles newer then 95...well at this point its usless and jus dead weight and a few horse is a few horse
Steven
SC
Im running a shorter belt, no harm so far. Alternator makes a little noise on first start up but i think its because its straight up crap lol
Paul
Don't bother. The air pump hardly takes any power at all - meaning negligible.
Steven
SC
no the alternator is old and junk. I needed a new belt and was throwing on longtubes, so I tossed the smog pump since I didn't need it Just one less thing under the hood. It's mainly worth it for just the extra room
95bananaGT
im jus tryin to delete stuff im not gonna need..and was jus wondering how you guys removed it...wat was the process after it was off..i undertsand im gonna trhow a code..i already am due to no cats
blkmcnasty
Illinois
Are you serious that i dont have to take my 95 gt to emisions in Illinois? I have only had the car for a few months but if thats the case then off road x pipe here i come! I have to go call Jesse White to make sure.
95bananaGT
you didnt know that???...ya anything 95 and under doesnt have to go...o and if you call him im sure your gonna have to make a campaign donation
Steven
SC
For one thing, 95 5.0 mustang will not throw a code due to cats. For two, it wont through a code for removing the smog pump. And lastly, all your doing is by passing the pump by installing a smaller belt. Easily done as it is said.
95bananaGT
wont it throw a code from the o2 sensor...i wasnt to sure about remvoing the pump would trip a code..how much does the pump weigh?
Steven
SC
not sure how much it weights off hand but it's a decent amount to take off. Dead weight. There are only two o2 sensors on the car and thats to monitor the air fuel ratio. The car does not have any cat efficiency monitors on the mid pipe. I run longtubes with an off road H pipe with no problems on quite a few 5.0 cars.
IMO shorter belt is the way to go, i bought mine at NAPA for about $50.
Smog pump removal clickhttp://www.allfordmustangs.com/techarticles/Smog2.pdf /urlhttp://www.allfordmustangs.com/techarticles/Smog2.pdf /url
