EMERGENCY Cam Timing Help
TxCobrA98
Hey guys, well we got the heads torqued down and ready to go but now we are trying to time these cams and we really dont know exactly how to do it. we have an idea but of course we want to be sure so we dont have problems at start up.
so does anyone have ANY diagrams or info on how to properly time the 4v cams? (to the crank and the intake to exhaust cams)
what seems to be throwing us off is the timing mark on the LH CAM sprocket doesn't seem to line up with the key way on the camshaft itself. the RH CAM timing mark lines up with the RH cams keyway though.
9psi 98
What kind of cams are they. I know that Comp Cams already adds 4 degrees into their 2V cams so you just drop them in like they were stockers and they are good to go. I'd call the manufacturer and see if their tech line can give you a hand with it.
Black97GT
I would say go check out SVTP there are more people that are 4v familiar over there..SN95 cobra section would probably be the best spot..most of those guys are fairly chill
T
TxCobrA98
i may do that if we can get it today. we havent worked on it since i last posted this because we had to order something but we are working on it today.. thanks for the help though guys.
