Engine build/ What's my best way to make more power
Slobra Moostang
As the title states, I would like to know my best options, for making some decent power. I'm new to mustangs, v8's, and American cars in general. I'm a new owner to this 1994 5.0 and don't know much about them.
It's a semi built 5.0 (I'll post some pictures, and info below). The last owners reason for getting rid of it was he stated that the motor in it (94 5.0) wouldn't hold as much power as he was looking for.
I told him that I was looking for maybe 600-700hp and he stated that "anything beyond 500 and that block will split down the middle.how true is this statement?
I'm going to be rewarded a decent sized signing bonus after I graduate basic training, and being a young careless kid, I was considering dumping some money into this car. If my hp goals are unrealistic, I'd like to avoid the trouble of putting money into this car.
Anyways, here is the build info, and my thoughts on what to get.
3.73 Gears with a rebuilt track lock
Tremec 3550 with Spec Stage 1 clutch
XXX F1SE Roller block
Ford 3476b hyper flat top pistons.
2MAE crank
Clevite rod and main bearings
Speed pro rings
Dura bond cam bearings
10:1 compression
Comp 35-328-8 cams
Comp push rods
1.6 roller rockers
comp valve springs
Arp head bolts
Arp header studs
Arp intake manifold bolts
Cometic headgaskets
Twisted wedge aluminium heads with 58cc combustion chamber
70mm throttle body
Cold air intake
Mac short tube headers
24 lb injectors
I planned on going with an On 3 Performance Turbo kit found here
http://www.on3performance.com/shop/1994-95-mustang-gtcobra-turbo-system/
With custom options for
1. 76mm ceramic ball bearing turbo
2. 60 pounds injectors
3. 320 lph e85 capable fuel pump
4. MAF kit calibrated to injectors and flange.
The total comes out to $2,588
Is there anything else, that could beat the price, and put me in a better position to make better numbers?
Would 600-700hp be a reasonable goal with this kit given my build? (not regarding transmission, suspension, etc.)
I don't mind swapping out somethings, such as lower compression pistons,a stronger crank, etc. but if it comes down to it, and I have to basically rebuild the motor, I rather save my money and spend it elsewhere.
Thanks in advance!
slow90coupe
Advance, NC
The block will probably split before you ever see 550. Why do you want 600-700hp? It's pretty much useless to have anything over 500 on the street in a Mustang platform IMO. If you really want 600+, better put a Dart block at the top of your list.
G_94_T
TN
+1 on all the above info
slow90coupe
Advance, NC
Also worth noting, a turbo seems to be the death sentence for a stock block 5.0. People tend to blow head gaskets every other week, then once they upgrade to really good head gaskets the block tends to be the weakest link. Blower cars seem to last longer from what I've seen, and nitrous cars tend to last a lot longer.
Nuttinbutcrumbs
Between the Red and the Rio
2MAE crank
Speed pro rings
10:1 compression
Comp 35-328-8 cams
Comp push rods
1.6 roller rockers
comp valve springs
Arp head bolts
Arp header studs
Cometic headgaskets
70mm throttle body
Cold air intake
24 lb injectors
Thanks in advance!
That's a lot of compression to be throwing boost on kinda. Are you talking 600 hp at the motor or the wheels? If I were you'd I'd skip the on3 and get a Vortech kit in either the 5-6 lb kit or the 6-8. It'll go on easier than the on3 has a better product reputation and better customer service (from what I hear about on3). I didn't see you mention you're fuel pump, if it's stock you'll need a larger one like a 255, you'll need one of you go a turbo or the Vortech. You'll also need larger fuel injectors at least 42#'ers but I think I'd opt for the 60's. Keep your same maf and have it "calibrated" via a tune which is something you'll want/need anyway. At around 8 lbs of boost or so you'll be making north of 400 whp which is a good amount and probably more than your suspension can hold right now anyway. That is unless you have a good set of rear control arms etc.
Oh and remember, they tax the sht outta those bonuses.
Don't Sext and Drive.
Nuttinbutcrumbs
Too much psi and poor tuning I think.
Nitrous cars lasting longer- it's because they only use it handful times a year.
evilcw311
Most Evil Member!
Louisville, KY
I know plenty of turbo 5.0's around where I live that last with no problem. Luckily we have a great tuner local who gets them all running perfectly.
It's a known fact that blowers are harder on the car in general cause of how hard they come on as opposed the the slower hit that a turbo gives. Not to mention the less stress put on your crank by a turbo.
They both have ups and downs. Turbos have more parts that you have to maintain and super chargers are harder on parts and are less efficient.
Now that I've vented that, I didn't see the op asking which would be better.
Nuttinbutcrumbs
No, no he didn't. Would you use an on3 "kit" though? Not me man
cameron57
After buying a on3 kit I wouldnt buy one. To many issues. Also 500 is the limit on a stock 302. I disagree with the 500 is to much on the street, but to each his own. A 351 will support more power with a 2 bolt but if youve got the coin go 4 bolt. And why not build a 351w 4 bolt if your building one it costs the same.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Nuttinbutcrumbs
He already has a 302 w aftermarket heads and such. He's wanting to make 600 hp using what he has by adding X amount of boost.
But really I don't think this guy know knows what he's getting into. He's wanting 700 horse power on a budget (hence the on3 kit) and there's no such thing. A 600-700 hp car needs a pretty expensive suspension setup. Heck even a 300 whp mustang needs a fairly decent suspension upgrade so you won't blow yer tires off or have your azz wagging all over the place.
I just realized that no one really answered your question on if you would make 600 hp w that kit. I didn't look at the link so I'm not sure how much boost you'll be making but I'm gonna have to bet no. N/A you're probably in the ballpark between 280-310 whp depending on what intake you use. If it's say 12 psi you might could make 450-460 at the tire which would be somewhere in the 500 crank hp range.
OP, do you have a car or just a motor?
If you have a car and I guess this would apply if you don't as well, step back from the power department Ricky Bobby. Before you start throwing money at the go fast stuff kinda evaluate the total project. How's my bottom end? How's my suspension? Is the body straight? How is my front end, nice and tight? Do I have enough brakes to rein in 600 hp? How are my tires? Is my exhaust old and rusty? Do I have enough $ for larger injectors and fuel pump? After I have the forced induction added do I have the $500-$700 for a tune?
Man, from a vet to a new boot, don't blow your whole bonus on an on3 kit.
For that matter don't blow the whole bonus on anything car related. Set aside a little bit for regular life. Once the bonus is gone, it'll be kinda tough to support the hobby on an E4 salary.
Ps: what branch?
Slobra Moostang
So to sum up what I read: My block is junk, for the goals I'm looking to reach. If I wanted to make said goals, I'd need to go 351, with forced induction in order to make good power, reliably.
Or......merge into the modular world. A coyote swap will be cheaper than a built windsor capable of 600hp and far more reliable. Best of all, the engine is stock. Put some psi in the ports and youll get your 600hp. Im not bashing the old school here, just opening the eyes
Nuttinbutcrumbs
Kinda.... Are you building a race car or a street car? Are you wanting to have a car that's quick enough to hold its own on the street against just about everything that you'd run across on a Sunday afternoon? Or are you trying to strip the car down to "bare bones" so you can run a 9 second 1/4 a few times a year?
If it's the first case scenario I think that your horsepower goals are way too high and way too unrealistic, and pseudo fast and the furious esq.
For starters a 700 hp 95 mustang requires some serious money and you're not going to get there w an on3 "kit". Like I stated previously, it takes one heck of a car to handle 600 hp. We're talking everything from top to bottom. A 200k mi mustang GT with all original parts except for the 600 hp motor isn't going to cut the mustard.
I'll end with this, if you run the motor as is without any type of forced induction you'll be quick enough to not get embarrassed by too much on the street as long as the road isn't too long. If you were to add 100 more hp via "small" blower (say you're at 300 now and the "small" blower would put you above 400 whp) You'd be able to run with the best of them as long as your rear suspension and tires are good.
The moral of the story is you don't "need" 700 hp and I don't think that you can afford it.
Nuttinbutcrumbs
He can't afford a $10k coyote swap, he's looking at a $2,400 turbo "kit":
A new purchased package includes 0mile complete engine(throttle body to oil pan. even headers), wiring, ecu, electronic pedal, mounts....etc. This kit sells eveyday for around $7k. Alot of rebuilders are going this route too.
The kit can be cheaper by sourcing the parts separately and scavenging a used engine.
400+rwhp with 87octane! It just makes sence! Sad but technology has caught up to bite the engine builders profits.
Nuttinbutcrumbs
My $10k guess was fairly close. Will the t5 work?
white95
Apex Junky
Prairieville, LA
Nuttinbutcrumbs
Best advice in the entire thread
If you want 600/700 with some resemblance of streetabililty, then you need to look towards a 4.6 or 5.0 swap as previously mentioned.
Hell, even a turbo 5.3 :gasp: would be a better choice.
The valvetrain modifications alone aren't worth the hassle when the newer, smoother overhead cam design takes the headache out of the equasion. This is coming from a guy with a built 410w no less.
It can be done, but you're not going to do it with your current budget. Sorry.
Carolinastang78
