errrr. smog pump dieing
it's making a helluva noise. Does anyone know the belt size to bypass it.
I have to leave it installed because I need to get sniffed every year.
Also looking for a fox smog pump elbow. I'm going to be switching over to a fox pump because it's cheaper.
blk94_cobra said:
or jsut buy the smog delete from american muscle for 64.95
Did you see the part where I have to get smog sniffed every year?
I think it would be easier If I just get a shorter belt and bypass the pump instead of pulling it all the way out.
RossA81
Monkton, MD
FYI 90.5 was too long on my car and bottomed out the tensioner which made a nice knocking sound. I ended up with a 90" Goodyear gatorback belt. Fits perfect and put the tensioner right in the middle of its travel.
Ross
currently I have a o/r H so the smog pump isn't needed. yet
If you have cats you need the smog pump so the cats will work correctly.
If your luck enough to live in a state that doesn't get smogged tested, the pump (and the cats) can be removed thus cleaning up the enging bay and removing 1 more thing the engine is driving.
GT Rob said:
Live in Texas we do have to test. So when i change my headers and exhaust i have to leave the smog pump on or bypass it
some people will understand is a mustang. lol
HISSIN50
FWIW, a pump that isn't used for a while can deteriorate quickly. It might sound like crap the next time a belt is put on it.
If you only use it occasionally, you can take it apart, clean and grease it. It's best to have a spare one on hand though because sometimes the mainshaft bearings seize to the mainshaft (the pump gets destroyed when you pull the rear cover off).
good info I'm not to worried about the current one. FUBAR. I might take it apart to see if it can be lubed and cleaned.
hdcarlos
Will rerouting with a shorter belt turn on cel? I have the cross tube and cats have been removed. Smog pump sounds like trash...
HISSIN50
Not unless something else is compromised.
