fans don't work!!!
stang4u2nv
on a previous thread i posted that i had finished my HCI combo but i'm a having a problems the fans do not want to kick on. The fans do however turn when you open the ignition only for a split second so i know there is a signal from the ccrm or maybe i'm wrong also everything was working before the tear down.. I checked the coolant temperature sensor and it is connected, and all sensors appear to be connected except for the air charge temperature sensor, will this sensor trigger a chenck engine light?becasue mine is on.....thanks in advance...
stang4u2nv
The car was running perfect before and everything worked electrically and also when i turn on the ignition the fans come on for like a millisecond and then they shut off.. i was watching the temperature on the gauge and it went up to like 200 degrees and the fans never came on.... any advice on what could it be would be great thanks alot.....
ryclef331
My fans never kick on when i just turn the key on...you got something else going on there. Your CCRM might be giving up the ghost on ya. Hook your IAT sensor back up, reset the ECU and try again. Again though, my fans never just kick on for a split second. If you go to the write up at that top, you might be able to tap into the wire on the ccrm harness, ground it out with a switch and run the fans manually as a temp fix.
Stangbangin
my fans used to kick on for a second then quit when my battery was low...but that was with the stock computer they don't do anything no that they're manual..does it start>>??
stang4u2nv
Well i just reloaded my tweecer tune and guess what the fans work but i'm noticing a weird sound coming from the fan it self and it the fan goes really slow like if ti was burned or something....
