Fiero cradle bolts??
jojo22
swapping the motor in an 84 fiero, the front cradle bolts will NOT come out, I have the nuts off, but the bolts will not slide out, tried heat, c-clamp to push them out, and many other things, anyone know a trick??
BFH= Big F'n Hammer.
Are you talking about the engine cradle
Is weight still on it, motor still in it?
Did you look in the Haynes/ Chilton manual for the removal?
J
jojo22
The engine and tranny are still in, however I have a cradle dolly underneath it and it's setting on that, os no weight is really being held by the cradle. I looked in the shop service manual and all it says is remove bolts. Also everything I can find online says the rear two are the hardest but they came out easy. I'm pretty sure the bolt is rusted to the sleeve in the rubber bushing.
ryclef331
are you sure the bolt itself doesn't thread into whatever its in? I.E. you gotta turn it to get it out?
96GTPlanB
