Finally a decent set of 1pc. projectors
NmcgrawJ
Anyone have them yet? Definitely moving in the right direction design wise from the 1st 1pc. design.
N
NmcgrawJ
Whoops....
and they arent projectors. They are just a 1pc setup....similar to our version of the 99+ stock setup.
silver 4.6
loving the white and red combo
although im not sure it would go with silver!
switch96
JDM? lol they're a step in the right direction but I still like 2pc better.
ReplicaR
Looks interesting. Problem with making one piece design on a Mustang is that pointing system is still the same, so rather than moving reflector inside the housing, the whole headlight has to move. This very often results in turn signals sitting weird. I'd want to see those on a car I guess.
They aren't projectors and look like this.
These pics were when I popped them in and weren't adjusted.
They are also not a direct replacement. You need to trim out some plastic on the header to make fit good.
Twista
So what do you have installed now? The 1 piece or back to the 2pc?
mustangmike98gt
They put more black plastic in them then the first ones that came out. Mine were the original black version but now its more. I like the new black style but they look extra plastic and cheap.
I'm rolling with the 1 piece, the light output is better then the 2 piece and probably better then those that are posted above with that big black plastic divider blocking peripheral lighting.
R.C.
