Firewall steering shaft bearing
Staff member
Lawrenceburg Kentucky
OOPS...Forgot to add the link
Ctucker
Pennsylvania
Here is a cool one! A direct replacement firewall mounted steering shaft bearing to replace an old deteriorating factory unit.
Having a hard time installing my MM shaft through the detroit bearing. Have any helpful hints on how to align shaft and get bearing pieces to slide together?
Staff member
Could be a scenario where a little bit of sandpaper and polishing on the shaft to get the exact fit needed?
Ctucker
Pennsylvania
Its more the firewall bearing insert is being a PIA. Think I'll try to take bearing and sleeves off then reattach it all once shaft and sleeve are secured
Staff member
OH ok, i get it. You 1st mounted the firewall bearing and then trying to slide shaft through at crazy angles?
I think your idea of sliding all together then installing is a better scenario. And you may find that some shaft polishing will be needed to slip that bearing on. Hopefully not to much tho, because thats work and its not fun.
