First Time at the Track!
98v6er
Central Florida
Well last night I went out to OSW to check out the drags like I do almost every weekend now, and decided to run the my car. Mods are cold air intake, underdrive pulleys, true dual exhaust w/ o/r x pipe, and steeda tri-ax short throw.
1st run- Spun first past the 60' and a bit into second.
R/T- .155
60'- 2.867
330- 7.607
1/8- 11.299
MPH- 66.21
1000- 14.489
1/4- 17.165
MPH- 84.42
2nd run-
R/T- .637
60'- 2.554
330- 7.059
1/8- 10.723
MPH- 66.55
1000- 13.902
1/4- 16.571
MPH- 84.59
3rd run-
R/T- .379
60'- 2.633
330- 7.143
1/8- 10.795
MPH- 66.77
1000-13.961
1/4- 16.617
MPH- 85.00
Any thoughts or tips are greatly apprieciated. Keep in mind this was my first time ever going down the strip.
duff daddy
Well first of all Good job getting out and experiencing the sport. Next, its hard to tell ya what your car will run with out a list of modifications (power and weight) and from there we can try to help you. 60'times are key to this thing. If you can drop just .1 off your 60ft you generally will lose .2 on the big end. Don't be disappointed in the speed or times, this is a sport of driver and car ability as you get better your car will perform to its greatest possibility.
98v6er
Central Florida
Yeah I'm not to sure what the power or weight of the car is. Also still running stock 2.73 gears and open diff. But I know what you mean about 60' my second run was much better because I figured out how I needed to work the clutch to stop the wheel spin. Definitely hoping to getting it back out on the track again soon :thumbsup:
98v6er
Central Florida
atlanticblue98 said:
your car has got a 10th or two left in it.
i ran 16.6@83mph and a 2.3 60ft with my auto, CAI and true dual exhaust. stock 2.73's and open diff
I saw that in the 1/4 mile times thread, I figure that the car can run a solid 16.3. Next time I am out there I'm gonna run lower tire pressure cause I was running 35 psi. And I need to get used to launching on the track.
atlanticblue98
you'll get better with time. 19mustang95 has a 7.5 axle with 4.10's and a T-lok for sale
98v6er
Central Florida
Damn I wish I had the money right now, I just bought the parts for my drop. I'll eventually get a t-lok and gears.
joekd
Ct
Tire PSI won't make a huge difference with street tires, thats more for DR's or true slicks
98v6er
Central Florida
Ohh gotcha, thanks for the tip... I guess it's just gonna take some practice launching to get those 60' times down.
Venom351R
Maine
Yeah get that 60' time down, thats your biggest issue at the moment. Your going to need a good set of Drag Radials to improve upon that. Street tires at the track are garbage. And like Joe said dont bother messing with the PSI with street tires its pointless and don't do a burn out w/ them either. Street tires are the exact opposite of a Drag Radial or a slick. Street tires dont like to be heated up and dropping the PSI will make 0% difference.
98v6er
Central Florida
Good to know... I was only doing a tiny burnout just to get all dirt from the end of the track off the tires
Venom351R
Maine
Its fine to clean the dirt and whatever off them but beyond that its not doing anything but hurting the 60'further
98v6er
Central Florida
So I've heard... I did a bunch of lurking around the track section when I knew I was gonna run it, hell I even played a reaction time game I found on google to practice haha
Venom351R
Maine
The whole run can be blown in the first 60 feet. The only other thing that will hurt a run that much is a mis shift, non issue for auto's though
98v6er
Central Florida
I figured... I actually did mis third on my 4th run that night, was kinda bummed I didn't get to run again after that.
