Flat black 1998 Build(3.8L to 4.6L)
B
New York
[video=youtube;mxu0hM3IfuE]https://www.youtube.com/watch?v=mxu0hM3IfuE&feature=youtu.be[/video]
Sorry for the horrible quality, and shortness, i thought i recorded more.
Now I'm going to spend the night updating this thread
punched281
Colorado
Congrats! I remember when mine fired up first time, good feeling! Hopefully there aren't too many bugs to work out
B
New York
[video=youtube;htZtwD_vSzo]https://www.youtube.com/watch?v=htZtwD_vSzo&feature=youtu.be[/video]
fuel pressures out of whack
Burninriverdiver
Glad to see it start!!! Great job man. As far as the fuel pressure dropping, did you replace the fuel pump? Im not sure if the v8 is going to require a bigger pump than the stock v6 pump can handle. Just a thought, I could be way off of the true problem. Good luck getting the bugs worked out
punched281
Colorado
Did you swap all the pats stuff? Mine did a really similar thing and I couldn't get it figured out so I HotWired the fuel pp to a switch
B
New York
I was thinking this but the part numbers seem to be the same on fords website
B
New York
Ugh i don't even know anymore, today the pressure was pretty normal and i count find any kinks or anything in the line
Me too, never could figure it out either. Does the fuel cut after the same amount of time every time you run the car?
It sort of does this, i timed it twice and they were within 10 seconds of each other
B
New York
Well I found a fuel rail, but the seller decided to cut the fuel crossover lines -_____-
B
New York
How did you wire this up, I might as well try this
I emailed BAMA and hopefully they will tell my why its stalling with PATS turned off but if not I'm going to try to wire it up
punched281
Colorado
Yea it might be worth it just to narrow it down too. I used one of the wires off the inertia switch in the trunk and went from there to a switch to power. I would put a fuse at least in there too.
B
New York
and you just leave the pump running the whole time the car is on right?
Cwacaser
