Flywheel Help (Found one. Is it the correct one?)
Twista
Update: Would this fit my car: http://cgi.ebay.com/ebaymotors/SFI-...t_W0QQitemZ180158763120QQcmdZViewItem#Details
There willing to sell? Just needs to be in good condition and ready to install.
Now, this is the only thing holding me back from getting the dang car back on the road! Theres a 11inch flywheel i could used but would run into problems, right????
Also can someone answer this question:
I called Ford and they said the part numbers are different between the 11 inch and 10.5 inch flywheels,
but does anyone know if a 10.5 inch clutch will work on an 11 inch flywheel,
I know it won't work the other way around but was wondering if maybe this would work?
reivaxtorres
Re: Flywheel Help+Anyone have a flywheel on hand?
yeah, it should work. i believe the flywheel for the 11" clutch has provisions for the 10.5" clutch. hang on, let me dig into this a little deeper, i remember there being a thread about it in another forum.....
EDIT: damnit, i cant find the thread, so im not going to give out false info. im about 50% sure that the flywheel for the 11" clutch will fit the 10.5" clutch, but i cant be certain. anyway you can test-fit the pressure plate onto the cobra flywheel? (i know 100% that some after market flywheels have provisions for both, but im not certain about stock).
T
Twista
thanks thatll be helpful. If it does work than we can get this clutch install going asap
reivaxtorres
wait a second. what year mustang do you have? unless its a cobra, a flywheel for an 11" clutch wont work because you have a 6 bolt crank (im assuming the pic in your sig and avitar is the car in question) and all mustangs that came with an 11" clutch were 8 bolt. (with the exception of the bullitt)
T
Twista
i have a 97 Gt. I think the other 11"inch flywheel is from an cobra.
reivaxtorres
yeah, then it wont work for sure. cobra's all came with the 8 bolt flywheel.
T
Twista
crap i was wrong.
my 11 inch flywheel is a 6 bolt tho
it came off my gt
01-04 gt's came with the 11 inch clutch
So, it didnt come off a Cobra. So would it have worked?
reivaxtorres
Twista said:
crap i was wrong.
it came off my gt
if it was a 6 bolt flywheel, yeah, it would have worked.
T
Twista
reivaxtorres said:
Twista said:
crap i was wrong.
it came off my gt
yep, it was a 6 bolt from a new egde GT. Ill just wait to my correct 10.5 comes.
thanks.
