for those of you running Cobra rear brakes, please chime in
GaryG
since the GT im buying has Cobra rear brakes, would i be able to run 15x10 Pro Star wheels, considering the rear brakes only 11.65"?
and once i buy the Cobra front brakes, since their (iirc 13") would i have to run the 17x9"+ wheels up front?
ThePope
I'm not sure about the rear brake setup but I do know once you do the cobra front brake swap, the smallest rim you can put on is a 17 inch rim. 98's come with 17x8 from the factory and the cobra brakes clear them just fine. You shouldn't have a problem.
scarface
Guest
you will have to run a small spacer or grind down the caliper/banjo bolt a bit. It is doable.
G
GaryG
Scarface- r u referring to using a small spacer on the rear to make them fit?
scarface
Guest
yeah, the problem is the wheel rubs the banjo bolt on the brake line... Im sorry I dont have time to go to other forums to get you specifics, however search corral.net Thats where got got my info way back.
