Fox Coupe Build
VooDoo95Cobra
Arlington, Texas, United States
Never posted much on my build, i have had it for a couple of years. 5 Lug conversion, UPR K member and coilover setup, upr bumpsteer kit, upper and lower control arms, Caster camber plates, strange 10 way shocks, Maximum Motorsports 6 point cage with swing out door bars. 99 gt brakes. I guess thats about all.. the car is an 1985 coupe but when im done you wont be able to tell. I just got 87-93 core support and smooth fender aprons. I have all of the body panels and glass for the 87-93. just have to keep on moving.
VooDoo95Cobra
VooDoo95Cobra
Ya i saved this car. I found it in a field and bought it off the guy for $250. It was a v6 but the body was perfect, the only problems was the core support was crushed because they put a cable around the entire core support to move it, and the passenger side fender apron has rust because the battery was in it. but as you can see all that will be fixed.
VooDoo95Cobra
VooDoo95Cobra
ya, the 85-6 front end was in bad shape and i side swiped a tree in my 93 4 banger so i still had a perfect 87-93 front end. plans are a large bore small stroke 331 built for high revs. want to road course it. still need the coilovers and other odds and ends for the rear suspension. new swaybars and bushings. subframe connectors. I want it to be a weekend track car but still be pretty.. paint will be fords new tuxedo black.. LOTS of metallic in that stuff.
