front to back brake swap???
MuscleInc1320
i have a question is there any way that i can take the front brake calipers and rotors off a sn95 and put them on the back? its the same lug nut pattern so i dont see why i couldnt. i reason i am interested in this is because i have the opportunity to get some front brakes off a sn95 for cheap and i figure it would be a cheap and easy upgrade for my stang. i was just wondering what you guys thought.
ryclef331
The caliper is different....I SUPPOSE you could have brackets fab'd up but I don't see it being worth the time....
Slow95Cobra
i wouldnt waste the time trying. just buy the 13" brake kit for the rear, and cobra calipers and rotors for the front. fairly cheap way to upgrade on all 4 corners
Slow95Cobra
the only problem i see is that the factory rear caliper/pads, would touch but like half of the rotor... with would kinda make the rotor swap/making bracket....etc. kinda pointless.. plus. front calipers wont work because then you would have no e-brake.. and remember... brakes are hyd. and e-brake is supposed to be mechanical, so if the hydralics fail, you can get the car stopped with the e-brake.
