fuel pump pressure!
Venomous96Cobra
Central Florida
okay anyone know how much pressure is needed to determine whether a fuel pump is good for startup?
my chiltons book shows that the pump operating at idle needs to be between 30-45
but what is needed for start up? mine is at 40 the car turns over but no start i have spark on all 8 cyl, fuel filter was just replaced any ideas suggestions, etc?
1995 5.0L
toyman
1995 5.0L
40 psi is more than enough. The fuel pump is normally delivering fuel to the regulator at about 70+ psi. Are you sure there is spark? The only other reason would be the injectors not opening. I believe you will need a noid light to test the injector harness.
95 svt cobra
DESERTCOX05 said:
look into a bad dizzy for the no start problem. they're known to go out
This. Also, did you mess with your timing at all? you could be off 180*
toyman
shifter said:
as are the TFI modules
Yes, but he said he had spark. If either the TFI module or the stator (PIP) failed there would be no spark.
